Here's some info I just received from Taylor, they too produce high quality wires. This should get you a set of black, Spiro Pro 8MM wires that will work with the stock distributor cap, and have 180* plug ends. Note the length of the coil wire. Other colors available for those more colorful than I:
The part number is 73055. You will also need a crimp tool (43390 or a similar part) to install the terminals. Follow the directions in the box and you should have the set on in about 40 minutes. By the way, the coil wire for this set is 36” long so you will have plenty of wire to trim to length.
Thank you for choosing Taylor,
Mike Birch
info@taylorvertex.com
Customer Service/ Sales Representative
Taylor Cable Products, Inc.
www.taylorvertex.com800-821-3600
