Hi all,
Not a Pantera question but I'm building a rat rod using an LS3 truck engine with ECU. Does anybody know what gauges I could possibly use for speedo, temp, oil pressure, voltage, fuel that could be plugged into the diagnostic port of the ECU? I'm not the mechanic on this part but sounds complicated to wire aftermarket gauges for a LS set up. Any advice? Thanks.
