You can replace all the bulbs without removing the speedo & tach, if you're careful. Its easy to drop a bulb inside the speedo/tach cases, or disturb or unplug something else in doing this. Most of the bulbs are 2 watt 12V push-in type, and for illumination you can substitute 5 watt 12v bulbs of the same physical size. I also suggest you get a workshop manual or join a local club where there are experienced owners in your area to help, as adding big bulbs to the wrong sockets will not improve your lighting.
