i have been restoring 9189 for a number of years now. on my car the a pillers had rotted out where they connect to the sills. i cut all this out after bracing the door frame then removed the door. i then replaced the inner and center sill sections using custom made sections in thicker metal. i had to stich weld these in place as they are welded on to thinner gauge metal. when this was done i made up repair patches for the lower a post and stitched it all together with a mig welder
  • 0107
