Steering column been fitted back to my car after restoration. Before I fit the steering wheel I have 3 small parts to fit, spring, turn indicator cam and a small circular washer/spacer with a recess cut out of it (See picture below)
Have looked at the tech article on Pantera place but it doesn't show or mention this washer/spacer.
The fitting of the spring and cam are straightforward but where does this washer/spacer go, does it fit before or after the spring or before or after the cam.
Cheers
Horace
  • SDC11098
