I search for a steering column and steering rack.
I looked at some capries but I can not find the right one.
Who can help me ?
Thanks
Peter
quote:Originally posted by over50:
Can this be installed on the existing column in place of the existing switch assembly? What is the cost and availability?
quote:Originally posted by comp2:
BTW, it is controlled by a solid state micro controller. It does not care if the bulbs are LED.
I am thinking of making a budget version this winter for race cars. It would not be auto cancel but would still control the lights. I was thinking since race cars do not have a dedicated electrical system, this might be a good solution.
The micro controller has 25+ pages of programing so I need a week of winter snow to go through it and make the changes
I can drop the price $20-25 without the inertia sensor.
It doesn't use the turn signal stalk at all. It uses a L/R momentary switch on the dash. The flasher is just used as a switch connected to the box. It just reads a high/low voltage.
The micro controller controls the flash rate so nothing goes through the flasher itself.![]()
