Thanks for the reply. I've checked the steering rack bushing, it seems to be worn, it has a little play up and down and steering sliding shaft under the dash is ok, thats why I'm hearing a clunking sound sometimes. The steering wandering is more evidence on heavy travel roads. Done a wheel alignment today, drives a lot better. But not sure if the specs are correct for a GT5. The final results are: Front- Caster: 2 deg L. and 2 5/16 deg.R. Camber: 0 deg. L and R. Toe: 1/16" L and R total of 1/8". Rear- Camber: -3/32 deg L and 0 deg R, Toe: 3/16" L and R total of 13/32". These specs are close to PPC street specs I've got.
