It appears there are a couple of tiny spot welds that hold the guts inside. I used some stripper to remove the paint but will have to thoroughly clean it prior to painting. Painting the inside will be a pain.
Ok I asked and he drilled them out and the replaced with tiny nuts and bolts so it could be easily broke down again, also the hanble was drilled or to get re-chromed two small holes drilled into the back of the handle and fixed back into place with tiny screws.
I did mine, stripped it down to have it crackle blacked, which took a long time, should have taken pics getting it back together was a trial but I had to take it to really good engineer to connect the handle.
Its one of those jobs you wish you had never started.
