wish everyone a great safe weekend-take someone out for a ride in your pantera! dumb q:is the pantera hand assembled,the reason i'm asking is the welds on the frame and other places they look like a hand weld jobs?otherwise getting thing pretty well figured out on how to repair and hide at the same time,using a 1/4" steel plate 8 1/2' by 11 1/2" for the shock and camber bar support and already bent to shape and the hole cut for the bracket,will use same 1/4" plate below that to support the bottom were i have yet to take out some rust otherwise all other rust is cut out and waiting for new metal pc.to be butt welded in,none of the repairs will show and are stright cuts more or less so replacing the cut out metal should be an easy chore.no ah shit yet except for equipment failure which is holding me up.well the birds are chirping so time to go to the garage,have a nice weekend.les
