FIRST THING I WOULD DO, IS MAKE SURE THAT BOTH RADIATER FANS ARE RUNNING! IF THEY AREN'T, MAKE THEM, EVEN IF YOU HAVE TO "SHORT" THE GROUND SIDE OF THE RELAY TO GROUND! I DID AWAY WITH MY RELAYS, AND WIRED DIRECT A LONG TIME AGO, JUST BECAUSE THE SENSERS ARE UNRELIABLE! SECOND, YOU SHOULD HAVE A 50/50 MIX OF WATER TO PRESTONE "ANTIBOIL" IN THE COOLING SYSTEM. THIS WILL RAISE THE TEMP. AT WHICH THE MIXTURE WILL BOIL. THIRD, I DOUBLE CLAMPED ALL HOSE CONNECTIONS, ANY LOSS OF COOLANT PRESSURE, NO MATTER HOW MINUTE, WILL RESULT IN OVERHEATING; AS IT LOWERS THE TEMP. AT WHICH A SOLUTION CAN BOIL! FOURTH, IF THE SENDER IS MOUNTED IN THE OVERFLOW TANK, MOVE IT TO THE FRONT OF THE ENGINE BLOCK, WHERE IT BELONGS. FIFTH, AT AN OUTSIDE TEMP. OF 90-100 DEGREES, 190-200 DEGREES ON THE GAUGE IS A NORMAL READING. SIXTH, YOU CAN "TEST" THE GAUGE, AND SENDER, BY DISCONNECTING THE WIRE AT THE SENDER, NOTE READING. THEN GROUND THE WIRE AND NOTE THE READING, THE GAUGE SHOULD BE AT THE MAXIMUM. IF YOU NEED A NEW SENDER (I DID) YOU CAN BY THEM AT NAPA AUTO PARTS FOR $6. SEVENTH, AND LASTLY, IF YOUR CAR IS AN EARLY '72 IT WILL HAVE THE BADLY DESIGNED RADIATER BAFFLE THAT HINDERS PROPER COOLING! THEY REDESIGNED AND FIXED THEM IN LATE '72-73. IF THIS IS THE CASE, YOU WILL CONTINUE TO OVERHEAT, NO MATTER WHAT YOU DO, UNTIL YOU UPGRADE TO AN AFTERMARKET RADIATER. GOING TO A PAIR OF "SUPER" COOLING FANS MAY WORK IN YOUR FAVER! GOOD-LUCK AND BEST REGARDS, MARLIN.
