Probably. If the sender is still in the tank it may not be grounding well at the bracket. Check the rest of the connections, especially the grounds under the dash.
marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
I second that!! Sounds like a bad/intermittent grounding at the sender or gauge, or under the dash at the drivers far corner, where 10 to 12 wires all come together for grounding at one screw. Marlin.
