I discovered that the previous owner had changed the thermostat and removed the by-pass plate. Since I was unable to locate another by-pass plate, I am designing one from a image from Allen Morris (1252) web-site where a by-pass plate is shown with a caliper measuring one of the features. I then can make a ratio of inches verses image size to get the rest of the dimensions. After I made a paper model I don't understand what retains the plate in the counter-bored hole. If it's a light press-fit it would be lost in the inaccuracies of the dimensioning.
I can't imagine that the plate just sits there even though it is trapped by design.
Comments?
Before you get too far in this, first is the engine overheating? The bypass plate is only needed if the engine is using a stock cast iron waterpump with a bypass channel built in, and many aftermarket pumps do not have this passage (such as the popular aluminum Weiand pump). Second, the "plate" is built like a freeze plug; it is slightly oversize for the hole, then is driven in and therefore distorts slightly. The diameter mismatch keeps it in place. With some care, a large std freeze plug can be modified with a 5/8" center hole to work with a 351C-specific thermostat, assuming you really need it. But wrecking yards are full of junk 351-C 2-V blocks with cracked cylinders, thrown rods etc. If I needed this plate, I believe i'd look there (with a big screwdriver to pop a used one out). Cost should be a smile & a handshake....Finally, some of the usual Pantera parts vendors stock a sort-of-replacement for this plate, or have scrapped engines around. Call around & inquire.
I didn't have an over-heating problem, this project started as a leaking orginal water pump, dated radiator and orginal fans that stayed "on" all the time. The new aluminum water pump I selected has the port for the by-pass. I didn't think to try a wrecking yard for the by-pass plate.(engineer out of control) I thought from the past posts that it was a preference to use the by-pass plate.
I also used your advice to make a custom shaped pipe to correct the coolant tank/pipe mismatch. I used 1 1/4" copper to fabricate it, but it substitutes the standard elbow in front of the oil pan.
Thanks for the help.
The only thing I might add, Jon, is, don't waste your time with tearing down 351-M or 400-M engines. In these crossbred truck motors, the bypass is cast iron, part of the block. M-series engines are 1" taller than the 351-C and theres a sort of rib above the thermostat area that doesn't exist in the Clevelands. Good luck-
