from the first moment I saw the picture the image was spinning CCW, and no matter what I did I couldn't get my brain to see it spinning in the other direction, like you are supposed to at first.
its not your brain it the website that spins her CCW.
Hmmmm, I don't think so.
Get another person to watch it with you, as I have. You will find it can rotate to the left or right and switch directions - but each of you will not always see it doing the same thing at the same time.
And yes, while there is an occassional glitch in the program it is only an abberation, not an explanation.
