Does anybody have a picture on their website or that they can email me? I am looking for how the stock bracket attaches to the manifold and the throttle cable (also stock)attaches to the carb. thanks Gary fordgt@atlantic.net
Its an L-shaped post with a hole on the bottom for the ist manifold bolt on the bottom and a second hole near the top. The throttle cable passes thru it & the jacket is restraine by an e-ring. The cable ends screw in/out for length adjustment & attach to balls on the carb & pedal. A slide-lock retains them to both.
I think I have an image from the PCNC April 2000 tech session. I remember taking a few images of Drew's car getting timed. The image might contain the carb bracket, but the PCNC website is temporarily down, and I can't check yet. http://www.norcalpanteraclub.com/april2Ktech.html
