Originally posted by Garvino:
Does anyone have a picture of the bracket used to move the throttle cable forward in the car about an inch when using a Holley carb?
I found an old thread on it but can't come up with any photos.
Here is the link to the old thread:
Throttle Cable Bracket
There are some close up images on Pantera Place that show a standard Holley carb installation with a stock replacement throttle cable that would be used on a typical Pantera that might be helpful. The cable mounting bracket is shown along with the throttle arm bracket.
Here is the link
http://www.panteraplace.com/page225.htm Note how the carb bracket positions the cable end so it is lined up with the front cable mount. The cable mount is slotted on one side so the cable can be easily removed.
Please be aware that extreme caution must be used when messing with throttle mechanisms especially if you are modifying them.
If you are new to the PI forum you might want to browse around Pantera Place some to familiarize yourself with the information available there.
http://www.panteraplace.com/ Many Pantera owners find the site helpful.
There is new information added almost most every week and the updates are marked with “new” icons.
Mike
