Looking for some advice.
I bought a throwout-bearing, the: 1625 from Federal Mogul. The number on the bearing itself is: 1625-12 FM-MEX TT. The inner diameter from the bearing is 41,3mm. The outside diameter from the carrier is 41,0mm, but there is small ridge witch measures 42,1mm. So it doesn't fit.
Do I have to buy an other one, or will I make the carrier a bit smaller.
I also bought a center-force clutch, do I need an other throwout-bearing for this? I once saw some pictures from a bearing witch was seized up because the finger-spacers touched the side of the bearing.
Who can tell me what to do?
