Those are reasonably easy they just pull out of the channel. Slip a putty knife behind them to start and they should come right out. The upright felts extend well down into the door so the glass rides in them even with the window down. You will want to remove the door trim for access, but you may be able to slide the new felts down the edge of the glass and not have to release the glass.
Good luck,
