Hey ZZ,
hope your weekend is going well my friend.
I assume you are running the oem Campy wheels, 15 x 7 front, 15 x 8 rear? If so, then the modern tire sizes that best replace the Arrivas are 215/60R15 front and 255/60R15 rear. The tires are roughly 25" diameter front, 27" diameter rear. You'll find both tires readily available from several manufacturers, but not in the same tire model of any given manufacturer. Both sizes are available however from BF Goodrich in the Radial TA line and Dunlop in the GT Qualifier T line.
Be careful who you allow to work on the Campy wheels, they need to know they are magnesium and should have the tools necessary to mount the tires without scratching the wheels. Do not take them to your local garage!
take care, George
