... not the little lead balancers, but the actual weights of your rim/tire combinations. I'm looking for OEM and replica weights, and oversized rim weights since there doesn't seem to be a central thread on this.
To start off the discussion, I'm running an aluminum 15" etabeta rim with 295/50/15s on the rear, wheel weight is 54 lbs. Info on front tire to follow.
Anyone know the actual weight of the OEM wheels? any others?
