Originally posted by MARLIN JACK:
NO! I DON'T MIND, I WAS JUST HAVING SOME FUN! AND I HAD TO LOOK THEM UP! SO HERE GOES: 1. REAR UPPER "A" ARM BUSHING BOLTS 58 FT/LBS. AT THE SAME PLACE, "YOKE" BOLTS THROUGH THE CHASSIS 58 FT/LBS. 2. REAR UPPER BALL JOINT NUT 58 FT/LBS. 3. TRANSAXLE FLANGE TO SHORT SHAFT FLANGE, (ALL, INNER, AND OUTTER-SHORT SHAFT FLANGE TO AXLE HUB/FLANGE) 50 FT/LBS. ANY OTHER QUESTIONS? I'AM HERE TO HELP! HAVE FUN! MARLIN.
[This message has been edited by MARLIN JACK (edited 08-02-2002).]
Thanks bunches!
Once again you come through in the clutch!
