Putting my ne Mcleod clutch in and wondering what are the torque specs for the flywheel and for the 6 bolts that hold on the clutch? Will be using BLUE loctight on both.
The torque specs coincide with the size of the bolt ... I think those bolts are 5/16 or metric equal ... 20 - 30 ft lbs depending on the grade of the bolts. grade 5 = 20 grade 8 = 30
