I'm installing the Armando pan and would like to swap out the rod bolts to the Boss 351 Rod Bolts (D1ZZ-6214-A), and Boss 351 Rod Nuts (D1ZZ-6214-B). The bolts and nuts have to be used together to keep the strength. I have a 72L with the CJ motor. I don't want to use ARP bolts because then I have to resize and re-balance the bottom end which was done by the previous owner on a fresh stock rebuild. The Boss bolts are rated to 180,000psi so they are a nice upgrade for a stronger bottom end.
I've check the local Ford dealer and was told the part numbers weren't showing in the system. I was referred to a Mustang parts company in SoCal and they referred me to a high performance junk yard. I don't want used rods bolts. Does anyone have a NEW set they'de like to sell or know where I can find them.
After all this time, for an orphaned engine who's parts likely sell slowly, old p/ns tend to disappear- sorry. But PAW in Chatsworth, CA has an on-line catalogue that shows p/n PAB-8241 for what appears to be gr-8+ rod bolts & nuts (in their cranks/rods section) for a 351-C. Browse to www.pawengineparts.com. My present engine (now 19 years old) has quite a few PAW parts inside and I had zero problems with anything. But since I have no direct experience with these bolts, call their Tech Line to verify they are direct replacements that will need no massaging in your rods. Good luck
Ok so I have tried allot of vendors to find an upgrade to rod bolts...PAW Ent.(part not available), Perogie (nope), many other vendors (you want what??? roll on floor) etc, etc. It's not looking good that I can just take a stronger bolt the same weight and size and just swap the bolt and close the bottom end without resizing, and re-balancing the rotating assembly which requires total disassembly of the motor. That was not my goal since the motor was balanced and everything was redone 50 miles ago by the previous owner...more importantly I should be spending time elsewhere on the car so it gets out of the damn garage (sorry for swearing George).
So now my question is, can the stock lower end(specifically rods and bolts) of a 72 CJ motor that is balanced and limited to 6000 rpm stay together reliably if the horsepower is pushed to 450 based on some of Dan Jones recommended mods such as cam, 10.5 to 1 CR? 90% street driven and a few track days per year.
A wise man suggested that he'd not heard that the bolts fail that often. If it's a part that fails 1 in 10,000 motors of similar mods, screw it I need to move on. But if it's 1 in 50 or 100, I'll bite the bullet becuase I don't want to be foolish on time and $200. So from everyone's experiences...is this a part with high failure rate given my intended use? THANKS IN ADVANCE FOR ALL YOUR EXPERIENCE. Geez, I've forgotten how much time these little tinny projects can consume.
Pardon this comment, but I think you are worrying about nothing. It's balanced, and you're staying below 6k rpm. I'd bet that many other parts would fail before the rod bolts (like the rods themselves or the rod bearings if you're running hard). I know that more than a few of us have flogged Ford V8s w/ all-stock bottom ends comprised of 40-year old parts. How many blown engines are caused by an internal bolt failure? I don't hear of it very often. Sorry, just trying to save you some time and $$.
And you're right, the Ford dealer is never a good place to go for old parts. I feel that any of the good old hi-per parts they had were bought up many years ago.
