Ok, checked the turn signal part. This is the red plastic turn signal cancel cam I think you were referring to ealier. It looks intact. Now I'm scared to put it back in. How does it go back in without scrunching it against the spring and steering wheel? Anyway, the turn signals still don't work. How do I check the flasher? Fuses all look OK and I'll check the grounds behind the gauges. Also, the headlight on one side doesn't work, (new light) nor does the fog light. The parking and tail lights do work however. I've got a wiring diagram. If I recall, even back in '72 the wiring was a joke but at least it was the LM dealer's problem. 30 years hasn't made it better. Any other procedures I should go through to solve this? Thanks
