I'm not sure why you've asked this question, but the usual reason has to do with aftermarket springs that aren't long enough. Such as the springs in my Pantera. I just put up with it, but there is a better solution.
When you're dealing with small diameter and "stiffer" aftermarket springs designed for "coil over" aftermarket shocks they are never the proper length out of the box. To take up the slack the spring manufacturers make very weak springs designed to fit in the gap between the main springs and the shock pre-load adjusters. Forgive me, at the moment I can't remember what those springs called. Some of you guys with a better memory will know.
