Does anyone know the size of the small trim screws that hold the door card around it’s edge to the frame of the door? They are smaller than available at my local auto parts store and I am uncertain how to properly measure diameter to match what is available on line. Do you measure the outside diameter or diameter inside the threads? I often see that these small diameter screw have been replaced, with larger more easily sourced, on several cars that I have worked on. I’d like to stay with original size. Thanks
