I would like to have a vacuum gauge in my '72 pre-L. I run the original Veglia Borletti gauges, and want the vacuum gauge to match. Is such a gauge available, perhaps from another make - Fiat, Alfa, or some other?
Here is what I have now - pardon the dust. Since I used relays to handle the accessories power, I used small toggle switches, which frees up room for gauges. Between the group of 6 switches and the clock, I have room for one more gauge.
North Hollywood Speedometer & Clock can make a vacuum gauge for you that looks like it's OEM Veglia Borletti. If they don't have the exact bezels in stock, just send them any used OEM Pantera gauge. They'll put VDO vacuum gauge workings in it and make a Veglia look-alike face.
