At some point someone tried to remove the washer nozzle on my car with a screw driver and buggered it up a little. I have the wiper grills off working on a set of custom wiper arms (I'll make a post about later) and decided I should replace it. I checked Wilkinson's but decided to strike out on my own. Wondering through the local Pick N Pull I found that a '92 Saab 900 uses a washer nozzle that mounts in the same or very similar size hole and it looks more modern. Napa part number ATM4254645. $5.99.
Steve
