I have just removed my std water pump to be replaced by a FlowKooler.
I notice the front face of the timing chain cover behind the water pump is corroded and badly pitted.
Would this have a significant detrimental impact on the operation of the impeller and water pump?
Reluctant to have to change it as it means dropping the oil pan, front balancer etc. Would it be OK to metal fill it then sand it smooth?
Cheers
