Thats Flux coated brazing rod used in HVAC business to braze steel pipe to copper tube. Its the correct method but paint will not stick to it even with metal prep. and the flux will definately make the paint bubble. If you have a fine tip oxy acetylene, use a coat hanger or go to the welding supply and buy welding rod for oxy acetylene torch. My 2 cents !! LOL
I have had great success in the past repairing cracks in body panels, loose spot welds, etc, using silver solder applied with nothing more than a plumbers torch. Like brazing rod, the silver solder is hard, not soft like tin/lead type electrical or plumbers solder. It makes a very strong joint.
your friend on the DTBB, George
OK accobra, today i echted it with phosphuric acid green primer..after roughfing it up. i laid on a couple of coats and then after several hours...applied an activated base of mettalic black... i am looking for a semi flat ..i belive i can make it stick with the ecthing primer. i got pics??
