Well I can't take it anymore. My head lights don't work turn signals are jacked up, things work when they want NOT when I want them to. So is there a wiring harness that the normal person can do themselves, I am fairly mechanical so I thought I would get some feed back on this subject.
Thanks to all.
Dennis
4726
Dennis,
If all your problems involve lighting, bear in mind that the emergency flasher switch is involved in all the lighting circuits. And it is well known to go bad and truly screw things up. A birds nest of wiring is attached to it so if you want to remove it and check it out, be very sure you get all the wire colors written down correctly. Likewise, the grounding issue on our cars can cause a bunch of weird, intermitent problems. I would surely attack all the ground connections and the flasher before going to a new wiring harness endeavor.
Dennis,
You don't need to change your wiring harness to make the headlights work properly .... perform this test first and let us know if the headlight motor lifts the headlights.
With the engine running, increase the engine speed to about 1200 RPM's and then try turning on the headlight switch. Increasing the RPM's increases the battery voltage and causes the relay to work.
If that works then we go to step 2.
Step one, if you do not have a wiring diagram get one. Even with the diagrams, and between the years some things are still different so the documentation is never 100% trustworth. I noticed that a few of my wire colors differed from the wiring diagram but the general circuts were documented. Having a guide is better then no guide. With few exceptions, most circuts are not complex (one of the nice things about a 30 year old car).
Being a system of quesitonable original design, some things defy normal sense but when wired properly they do work. Get a good voltage/ohm meter and start tracing the circuts. Best to use a A/C battery charger so you do not wear down the battery.
It is a time consuming process to trace each circut but the options are limited. Figure this to be a good winter project. Best to try and save the original harness. Easier for future troubleshooting or for other owners to deal with stock systems then a homebuilt replacement. One thing that will impact future resell value.
As mentioned earlier, check the grounds also the fuse box is known for not having good tension on the fuses creating interesting conditions.
