The impoprtant part is 12mm, 1.5mm thread pitch, and 60° taper.
Do you want pretty or light? I got some 12mm X 1.5mm that are two inches long from NAPA for the Gotti and Etoile wheels.
A standard Ford lugnut is 12mm X 1.5mm and a whole set weighs less than four of the 2" nuts. Or you can go shopping for the fancy Titanium Tuner Nuts.
Just a good looking nut Jim that will look good with our wheels. She should be about 5"4", 115 lbs, red hair,,,,no wait, that's a different topic.
You know what I mean...
Will go to Napa's and see what they got.
Thanks James.
I had a crash on my computer and lost a few e-mail addresses and e-mails. Send me an e-mail to cozland@cox.net so I have it and I'll send you a few of the things I've been working on. getting close to retirerment, aren't you :-)
Originally posted by pantera someday:
Okay COZ don't forget to email some pics,cause you know I have been waiting like a expecting mother for you to get yours finished.
Have the short studs on the front and the long one's on the rear. Eliminated the spacers from the rear with the new wheels and but still have the long studs. Not even going to go through what it takes to change them out to short studs.
Originally posted by Jim:
Escort ZX2 uses a chrome acorn nut that looks pretty good - if your studs are short enough. Check your local Ford dealer.
Coz, Summit Racing has a fairly good selection (Grip lengths) for 12mm X 1.5 Pitch. You should know what diameter you need for your particular wheel. The lug nuts I purchased have a black plastic, internal plug, that unscrews from inside the lug-nut, using an 'allen' wrench. Removing the plug allows these nuts to be used with studs as long as you like, just as an 'open-ended' lug-nut. Call then up, but be sure to Talk to someone who knows their inventory!! Good-Luck,
