Thank you everyone for your ideas, it shall be "B"
Magnaflow mufflers, the one's most everbody liked and the one's I just ordered today are P/N 14816. I called Summit racing and they cost $150 each, Magnaflow list them at $274.00 ????
Should look good, if not I'll cut them off and do something diff.,, at least it won't be so loud!
see the full line up at
http://www.magnaflow.com/02product/shopdisplayproducts.asp?zone=main&id=386
  • 14816
when I get around to replacing my mufflers, I plan to cut the rear-caps off a pair of MagnaFlows, shorten the muffler cans to the same length as the Ansas, then cut the back of the cans at an angle before I weld the rear caps of the muffler back on. That way, with the muffler sitting level, the tips still point upward at the proper angle.
Basically, modifying the MagnaFlows to duplicate the Ansas.
This will require a bit of TIG welding & buffing, but the result should be worth the labor & cost.
George
