Does anybody know if the Wilwood clutch masters are bolt-in replacements for the original Pantera clutch master? Wilwood has several models; part numbers 260-3374, 3/4", 1.1 stroke and 260-3376, 7/8", 1.2 stroke seem to be good candidates but I cannot determine if these will bolt on without modification. (I am presently using the long stroke clutch slave cylinder at the other end.) Recommendations?
[This message has been edited by Jon3613 (edited 11-04-2002).]
Most clutch master are not a bolt-on, not because of bore or stroke, but because the Pantera uses an odd-ball bolt spacing. Almost all aftermarket clutch masters are 2" center-to-center for the mounting studs while the Pantera used about 1.85"center-to-center. So one either remachines the brand-new master (if there's clearance for the nuts to turn afteredoing it) or uses one sold by the vendors, who invested time & money to get them built correctly. That mounting area just above the accelerator pedal is not easily accessed either, so mods are difficult at best. There are issues with getting the hydraulic line adapted too as aftermarket units route the output line differently and do not use European bubble-flairs.
