Hi all,
I am wondering if anyone has come up with a good solution to solve the problem of reflections from the illuminated speedo and tacho in the windscreen when driving at night. I have searched around and found one old thread, but no follow up on it:
http://pantera.infopop.cc/eve/...274/m/1931078556/p/3
I have a 1974 with single pod dash.
Cheers, Tim
Yes, I saw that in the thread, but was wondering if anyone had tried it and what the outcome was (or of anyone had come up with some other solutions).
Cheers, Tim.
A reminder related to a film to block light transmition scatter
I wonder if 3M "louvered" anti glare film would work on eliminating the reflections on the glass.
http://multimedia.3m.com/mws/m...dustrial-prod-br.pdf
price list
http://www.apioptics.com/3m-display-film-spec.html
After looking around for a while on the internet, I think that these films are the same as those used as 'privacy filters' for surf tablets, computer screens and mobile phones. See here (http://www.3m.com/3M/en_US/privacy-screen-protectors-us/?WT.mc_id=www.3mscreens.com). If so, then simply getting one of these from the local mobile phone shop or computer shop, cutting out a circle of the right diamter and attaching it to the speedo, tacho etc would solve the problem. I will get one and try it out and report back (if someone else doesn't beat me to it).
Cheers, Tim.
Hi all,
I have now tried this out and to cut straight to the chase - yes it does work, but I don't think I can reccomend it. The problem is that the film creates a kind of fuzzy, unfocused effect, so the instruments don't look sharp when you look at them. I will try to upload some pictures to explain.
So another solution is required.
Cheers, Tim.
  • film_used
Hi all,
now I have done an experiment with film on half or on ca. 2/3 of the instruments. When on half of the instruments it does not completely remove the reflection in the windscreen, as you will see from the photos I upload. When on 2/3 of the instruments it does remove the reflections entirely, but only if you rotate it round so it covers more of the speedo above the 60 km/h area - which is also the most important area of the speedo. The garage wasn't completely dark, which also creates a few more reflections that wouldn't be as clear if it really was at night. I guess I should also say I have the John Haass LED instrument lights in all my instruments - they are really great :-)
So, below, the first photo shows the instruments in the dark, looking directly at them with instrument lights on, with the film on the bottom half of the speedo
Cheers, Tim.
  • Daylight_film_on_half_speedo
So, to conclude. I haven't been for a drive at night yet to see how it all works, but using 2/3 coverage will seem to work for me, with my position in the car. I will probably only put the film on during night driving and then take it off the rest of the time, it is easy to put on and take off, with some special static film strips that come in the pack, or you can make it just a bit too big in diameter and it will slip under the chrome ring and be held in place.
So I can't completely reccomend the solution, it is not optimal, and is probably also reliant on your own position in the car. But, now you have something to think about :-)
Cheers, Tim.
I have simple solution, I have a carbon fiber dash and my auto meter gauges are bright they reflect as yours do, I solved the problem by installing a piece of black tool drawer inner on the dash (pod area) that keeps my radar, sun glasses,etc. from sliding off the dash, at night I just pull it forward it creates a proper hood that stops the reflection.
