Need Help with this one! My 87 GTs narrow body came from factory w/rear wing-Leave it on or take it off? Thanks for any imput!!
quote:If for some reason someone wanted a wing that actualy generated a little bit of down force, I think you would need the one from the Plymouth superbird in order to get it into clean air.
quote:also has any one had direct contact w/George Stauffer-He was the selling dealer for this Pantera to Charlie Seabrook-he has all docs and I am trying to get paperwork from him.
quote:Originally posted by Joules5:quote:If for some reason someone wanted a wing that actualy generated a little bit of down force, I think you would need the one from the Plymouth superbird in order to get it into clean air.
DeTom, You mean ala Pantera Si?
quote:Originally posted by maximus:
Thanks for all responses!! Looks like wing is staying on!! I will check dimensions! also has any one had direct contact w/George Stauffer-He was the selling dealer for this Pantera to Charlie Seabrook-he has all docs and I am trying to get paperwork from him.
quote:Originally posted by Peter H:
Maximus:
If you are undecided, run for a while with the wing and then for a while without. I installed rubber grommets covered in felt on my wing struts so they don't gouge my deck lid paint, and so I can remove the wing when I feel like it. I plug the bolt holes with cheap plastic plugs I buy at NAPA for a few cents, and it looks great.
