Once again I have a problem. I lost the drawing of the wiring connections to my Wiper and Washer switches. My wiring diagram seems to differ from what appears I Have. I am looking for the easy way out. which wire goes where looking at the switches from the back? The washer wires are Green and white. Which one goes on the left or right. The wiper switch has 4 wires. one a double green. then the orange, brown, blue. At the back of the switch on the left the 2 spades are wide apart. On the right they are close together. Which wire goes where.
I am now brain dead.
Verrry easy. Take you Power Probe & first find out the ~hots~ you're working with. Remember which TWO are hot. Now + power OUT to available wires. Washer for example, one comes in hot, THEN you find with the Power Probe which wire spins the washer pump. Bingo done. Now simply connect those two and forget that switch. Wiper? NP. Remember the one positive in. Power out the others to see which makes the wipers run slow. Ditto, fast. Now you're almost done. At this point, hold the switch in hand, power IN to any male. Simply flip to low switch position, & add the ~low~ that made the wipers work...to that male. Click to position 2, do the same.
If you don't have a Power Probe, use a VOM or test light. It's simple electrics. You're just finding whats hot, sending it on it's way to power up the wiper motor, & the outer, do the same. Send the power ~OUT~ of the switch to the wire that made the squinter pump buzz.
You'll be done in less than 10 minutes.
