Hi Lloyd, finally got my ZF back together, changed the cracked case and 2nd. synchro. What is the conversion for checking the preload on the differential assy.? ie. Wind a rope around housing, rotate with a springscale. Book says 3.5-5kp. Lbs.? conversion. Also, the partsbook shows 2 springs to retract the throwout bearing assy. Misplaced them? thanks for info Ken Edmonton AB Canada
