After looking around I see prices ranging $6k used to $11.5k new, so I'll have to open a crate up and take some picks make sure everything is in order and post it up on this ad.
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
If they have been in long term storage you'll want to remove the lower cover and determine there is no rust inside. If not rotated through the oil regularly moisture can be enough to cause significant damage.
If it needs opening up and going through then somewhere around the $4.5K mark may be closer.
No rust, they have lived in Nevada inside storage 30+ years, they spin smooth no visible signs of damage or rust, I am happy to take more pictures if needed. After much research I am asking $10,000.00 ea OBO. thanks..
