Would like to throw a issue I have with my 750 Double Pumper. It is a older factory modified 750 with the Four Corner Idle circuit, no choke(still has the choke horn), Air bleed holes drilled in the primary butterflies. I had this on a 351C and it was a great carb, I added the 50CC accelerator pump, that engine bogged(C6) off the line. Now I really think this carb will light up my engine.
The throttle bracket does not go below the throttle shaft, and it is peened over to secure it to the shaft. I talked to Holley and the tech seemed like he didnt want me to send the carb to them to install the proper bracket. The only idea Ive had is to cut the rolled metal off and install the proper throttle bracket. But to reattach the thing I can only see welding it to the shaft?
Help
Jeff
