Getting around to replacing my oil pan and while I have it off I thought I would replace the stock rod nuts with these 12 point ARP rod nuts I bought a while back. I'm keeping the stock rod bolts, so no resizing the rod end needed. Then I realized that the engine was balanced with the OEM 6 point rod nuts vs 12 point. Do I have a problem? Is there any appreciable weight difference that would require rebalancing the totating assembly? I believe these may be lighter, but have not weighed them. My questions:
#1. Am I over thinking this?
#2. Do I weigh both and see if there is any difference in weight?
#3. Do I buy the 6 point version of the ARP nut or just go with the 12 point.
I appreciate anyones educated thoughts.
