Where can I get this type of gas filler ? I think I like it, I need one, I see large ones sold in the stores for trucks,,, Where do you get the small ones ?
quote:Originally posted by george pence:
It's not "fake" DeTom! What's a body ornament with ribs on it supposed to do?
Truth is, several odd body angles are converging at that spot, and Mr Tjaarda used that little ribbed piece to make the junction pleasing to the eye. Does that spot on the car stand out as being too busy, or unattractive, or awkward to you? If not, then the little ribbed body ornament is doing it's job perfectly, and is therefore totally functional!
quote:Originally posted by DeTom:
The GT40 had air inlets there and I really believe that is what was intended.
Can you make it loud enough to hurt peoples ears when I drive by??? That would be real important to me.
quote:Originally posted by Panther:
Brad,
The pics you posted of the gas cap conversion are from my Pantera. After many emails between myself and Marlin, I returned from overseas this past summer fired up to get this done. Marlin was awesome from start to finish.
There are some obstacles Marlin mentioned, but nothing major. It helped to have a spare gill with gas door, if I ever wanted to go back. But after seeing the results, I won't. Good luck.
Ray
