Alex,
Very nice work indeed. I'm still working on an adjustable a-arm solution for the front and I'm intriguied by a couple aspects of your build;
1. Did you build in any additional caster to the upper front a-arm or are you acheiving that by offset spacing the heims at the body?
2. What is the front upper ball joint from? Does it retain the stock 10 degree taper?
Thanks,
