Straight from Marlin Jack
Posted May 15, 2005 10:00 AM
...All degrees are Positive. Front wheel caster angle= 2 degrees 40 minutes. Kingpin Front wheel= 8 degrees. Front wheel Camber= 0 degrees + or - 8 minutes. Front wheel Toe-In= 1/8" (1/8 inch). REAR wheel Camber(negative)= 0 degrees 30 minutes + or - 8 minutes. REAR wheel Toe-In= 1/8" to 3/16" (1/8 inch to 3/16 inch). That is all...
Marlin also mentions that these are for a stock car....possibly a good starting point for wide tires.
MARLIN
