I have run aluminium flywheels for the last 20 years. And newer had any kind of problems.
Steel pressure plates is also a noticable part of the mass so you should need something in between alu-steel.
The 351 are externally balanced, so you must put some weight in the alu-wheel. You can use regular steel inserts.
Goran M.
