What causes an engine to run on when you shut it off. Mine only does it when the engine has gotten up to full temperature, maybe even a little on the hot side. You turn the key off and it diesels a little. The engine was built to cobra jet specs so it can't be compression. The timing is probably real retarded, at least it feels that way. Is there something else can cause that??
