Does anyone have an alternative for the backup light switch. My replacement from the vendors shorted out and blew fuse 12. I'd like to find an alternative if someone has done this do you have a part number of what works?
Steve
quote:Originally posted by Joe 1974 L #6656:
i took the old switch out that broke off when I pulled the tranney and went to Autozone and matched the tread size and pitch. then tweeked the adjustment till it worked but it was 7 years ago
quote:THEN found out it was a Normally Closed switch!!
If I understand...
the backup lights come on when the starter is running.![]()
what is the reason?
how about when reverse gear is selected?
quote:Originally posted by Husker:
I believe what Peter was saying was that he found after installing the TR6 switch that it (the TR6 switch) was normally closed.
quote:I continually fail to understand the logic to explain why an owner would modify a permanent part of one's car, such as a drilled-out selector housing cover, when a correct vendor-supplied part is readily available.
quote:Originally posted by Rocky:
Yes, but Peter, I have to take issue with your choice of replacement clocks for the dashboard of your Euro GTS.
That golden Chinese replacement clock with the swinging arm (lower left corner of your picture)looks nothing like the original design.
I daresay it might detract from the value of all of our cars if it becomes a common modification....
