Originally posted by ilyes:
Hey guys,
So I need to get new springs for my heads. I went ahead with a Bullet cam ff280/371 and their guy told me to run the PAC 1220. I read something similar over here as well. What I don't get is this spring calls for 600' of maximum ift on PAC website. The cam has about 633 of lift after ash adjustment. Am I wrong or this spring is not enough?
You can answer your own question by measuring the clearances between the coils at your maximum lift.
I forget what the recommended clearances are but probably are going to be something like .100"?
That information IS on all the manufacturers web sites. You do have to find it and sometimes that alone is a chore.
What you are trying to do here is avoid coil bind and provide a margin of safety.
Coil bind is defined but in my layman terms if means avoiding the spring to completely close and act as one solid mass.
