I have a new Fluidyne radiator, but it's mounting tabs do not make it tilt forward like 'laydown' radiators. Currently have some sort of replacement fans that mount within the stock mounting clamps, but rest against the radiator and look like modern replacement fans that would be used with a laydown. Looks like the fans were modified, use motors are not nearly as deep as stock, but deeper new flat motors. Which are the best fans to use with a non-laydown application?
Thank you
