I am having an interesting problem with my 1973 Pantera. Initially all my signaling lights went out (brakes, and turning). After replacing the relay they all worked however the right blinkers now flash five times faster than the left. Thinking it was a blown bulb they were all changed out. The condition still persists. Any ideas ?
darryl_morgan@amat.com
Most weird lighting problems in a Pantera are due to a loose ground somewhere. Each light socket is individually grounded and there is a central ground under the dash, more-or-less accessible if the console gauge panel is removed. Remove the nut on the stud, wire-brush everything and reassemble. Tighten'firmly' but do not snap the stud!
