quote:Will the hose from the dry sump oil pump go into the cockpit? Or is that temporary...
I think that's what the braided hose with the thermo-covering on it is...
Originally posted by Push1267:
... it's a RoushYates 358 D3 ...
quote:You can't run in Europe vintage racing series with that engine ... It's not FIA legal
quote:high-end Intrax race coilovers
quote:Enough room for the caliper inside the wheels it seems
quote:Originally posted by Push1267:
Well, I suppose I was motivated enough to invest quite substantially in a set of high-end Intrax race coilovers specifically set-up for my car and it's expected use !
quote:impressive that you can fit 8-piston calipers inside the 15" wheel.
Kid, you're right about the color of the coilovers, I should have thought about that !! :-). Red goes with the exterior of the car !!. What version of the intrax shocks are you using?
quote:What is Rousch recommended refresh/rebuild interval on the engine? I bet in NASCAR they tear them down after every weekend!
A lower rev limit would be wise to get longevity, but where is the cam happy for vintage racing?
If I drop my race engine shifts by 1000 rpm to 9500 I get maybe another 250 miles between rebuilds....
Very long time since I updated this thread. Not much work going on sadly.
However, I thought it would be cool to do some historic graphics on the car. So here's what we came up with. Not all done and still need to change the Pantera script a little, it's too fat, but otherwise pretty close.
Replicating the Dubois car #2860 in it's 1972 Spa-Francorchamps livery.
Period correct yes, polically correct, not so much :-).
Sorry I fail to see whats not politically correct 😉
I looks really cool to me 👍👍👍👍👍
Fantastic job , A Gr4 (replica) is also on my wish list .
all the best into the New Year .
Simon
I can hear it now going up and down the parking ramps at the mall screaming at 9,500 rpm! I want to say, shift into second now!
OK, loooong time since some updates on this project.
After deciding to run the Gr4 car in the Danish Hillclimp series, and getting confirmation that it is in fact possible to classify the car in the Competition (B) Class for modified cars, I seem to have found some motivation to try and move the project along.
We did go through the engine - just to make sure everything is fine. So everything was inspected cleaned and found fine and put back together.
We replaced the main and rods bearings (some trick Elliot Coated parts from Yates), Cometic gaskets and vacuum seals and the crank was polished (just as a precaution). But everything were looking good.
Also had Scott at Eatmon Race Engines design a new cam for it, that moves the powerband somewhat down - i.e. with a max power around 8300 rpm but with a stronger more usable midrange. Still a pretty aggressive cam with a duration of 266/270 at .050. Power is reduced to around 750 hp.
The RYRE D3 heads had the titanium valves replaced, installed new PSI valve spings to match the cam and was vacuum tested.
Just need to degree the cam (the cam has 102/103 centerline) and the engine is all ready.
I notice you are using a timing belt ?
what brand ?
Simon
It looks great!
Looks fast!
Thanks for all the comments - to Simon, the belt drive on the engine is a Roush Yates.
Here's a little bit of an update on the project - it's been going a little slow but I did finish most of the modifications to the front-end of the car. Remember the car is being build to replicate the early gr4 Panteras (from pictures), as they looked when they first hit the track i the spring of 1972.
Here's the front - the huge oilcooler, brake ducts w/scoops cut into the front, modified grill (yes, I cut up a perfectly fine early chrome grill to copy the gr4 look - awesome !!!:-) ), aluminum headlight buckets incl manuel raising mechanism, aluminum hood and just finished copying the blade spoiler in aluminum (need paint).
Pretty time consuming work
Looks Fantastic, thanks for sharing .
How does works the manual rising mechanism ?
more pictures are welcome.
Simon
what rim size F+R and brand of tires are you planned to use ?
Simon
Fantastic work as always, many of the current crop of Group 4 race cars seem to have acquired the later GT5 style air dam. What brand tires do you have? I would be interested to see the headlight mechanism. Will you be replicating the adjustable sway bars as well?
Yes, the Gt5 airdam is probably much more effective than the simple blade spoiler - but that's not the point in this build :-).
The wheels are the Marvic Gr4 magnesium reproductions , 10X15 front and 14X15 rear. The tires are Avon all weather historic race tires, 10.5/23.0-15 and 14.0/27.0-15, that was what I was recommended to use by Patrick Hals.
For the raising of the buckets, I keept the the original gear, and removed the motor and did some trimming of the brackets (had to because of the radiator). So I can raise the buckets manually with the emergency knop. The whole set-up is removable including the aluminum bar. I only have this older not so good picture - I have made some smaller trimming and changes to the set-up since then.
I intend to have the original adjustable Gr4 sway bars fabricated. I do have the drawings and measurements of them, including the modifications that were done to the a-arms and the chassis - the center mounts were moved outwards in the rear.
I would need to find a company that can build the sway bars though - any leads? Julian, if you are interested in a set for your car too, maybe we can figure something out.
Kristian
I don't know what kind of bars you will be using but this company built custom axles and custom hollow anti-sway-bars for my race cars many years ago. Great job and no failures.
I was assuming I could just fabricate adjustable end links for my current sway bars, but certainly if the correct ones are available I would be interested in a set.
good news to see that this beautiful replica is progressing well !!!!!
It looks like an Italian movie star in a red dress. Very sexy, especially from the back. I'd definitely send over a drink.
Don't you need to run Webers like the factory cars did to qualify for vintage?
48 IDA Webers were homologated for the Gr-3 and Gr-4 but were options. The Holley #213 (list 4778) was the carb mostly used, I think. You do know there's a Swedish-run Registry for Gr-3 Panteras with a 14 page Supplemental Parts List that covers Gr- 3 and 4 parts. Browse to www.scuderiadetomaso.se, run by Anders Hellburg. He's still active- got an e-mail from him last week.
Hi Boss,
are you sure that it was a Holley 4778 that was specified in the supplementary parts list for GR3 and GR4? I think it only says List 213, which doesn't seem to correspond to anything, and everything I have seen posted seems to suggest great confusion about what the mysterious Holley 213 carb is. I speculate it is a date code and someone messed up when writing down the Holley model number and put the date code instead.
Cheers Tim
